Slic3r Prusa Edition 1.41.2-FINAL
Hi guys,
brand new Slic3r Prusa Edition 1.41.2 is out! This is a final stable release recommended to all users  😉
What is new?
This release is focused on performance improvements and bug fixes:
Improved OpenGL rendering performance on OSX Mojave #1250.
Fixed some crashes when slicing multi-material prints #1368, #1415.
Fixed invalid extruder assignment after switching from a multi-material printer profile to a single-material printer profile.
Supported printers:
- Original Prusa i3 MK3
- Original Prusa i3 MK3 Multi Material 2.0
- Original Prusa i3 MK2.5
- Original Prusa i3 MK2.5 Multi Material 2.0 (new)
- Original Prusa i3 MK2/S
- Original Prusa i3 MK2/S Multi Material 1.0
Download link:
 https://www.prusa3d.com/drivers
Previous releases:
Slic3r Prusa Edition 1.41.2-RC  https://github.com/prusa3d/Slic3r/releases/tag/version_1.41.2-rc
Please report any bug here:
 https://github.com/prusa3d/Slic3r/issues
We look forward to your feedback!
 / Knowledge Base
Re: Slic3r Prusa Edition 1.41.2-FINAL
Is it possible to make a "feature request" for a Slic3r software?
The requested feature is : " Solid first layer" or "brim for inner parts"
Let say, the part to be printed starts as several cylindrical surfaces (like tube inserted into tube) with intervals between.
Sometimes I receive shift of inner part and part becomes broken. I assume if inner part would also have a brim (as well as outer) it can be prevented. Or other option - if the first layer will be solid and serve as a brim for inner parts.
Would that not be a raft?
Oh... Didn't notice it earlier. I'll try it.
I have a feature request... Relating to MMU2, can we have individual control over the extrusion width used when printing the wipe tower? We could have regular extrusion width on the model being printed, and an increased extrusion width on the wipe tower would extrude more material in a shorter period of time. I would expect the differences to add up to quite an improvement in print times.
Is this the place to make a "feature request" for a Slic3r software?
Request:
When using the MMU 2.0, have the ability to completely print an object dedicated in a safe zone (so the extruder headed will not crash into the completed printed object) for each extruder before moving onto the next safe zone to completely print another object with a different extruder.
For example: If I have a small cylinder that I wanted to print with each of the 5 different materials loaded into the MMU without switching materials between layers but rather finishing the first object completely with one material, move on the 2nd object with the 2nd material, then the 3rd, etc...
I am noticing in Slic3r 1.30; that there is "Use Adaptive slicing" with Adaptive quality (with scroll bar for 0 to 100) and Match horizontal surfaces.
Could Prusa add this to the 1.41 version?
I would like to see, MMU2 status. any errors or why the MMU2 is disabled. selftest?
I have been unable to resolve my issue with my MMU2. All connected and triple checked everything.
On the MK3, it states, MMU N/A?
Just bought the printer and using this slicer and so easy to control and setup, its great, even I teach my wife how to use 3d printer thanks to this slicer, makes everything better and easier.
changed my nozzle to 0.6 and presets are so good nothing else to do. easy to print.
would you please add 0.8 nozzle settings too, we want to print bigger items faster!
thank you for your efforts for making printing easy and enjoyable!
I just got an epic set of spools of the Prusa Orange and Black Prusament PETG. which option from the materials drop-down list corresponds to this material?
I'm traveling the last few days so I'm not looking at my copy of Slic3r, but I do recall a recent addition of Prusament PETG as an option.
In all previous versions of Slic3r I've been able to have the horizontal Top Shells set to "0" and it would leave the infill exposed.  This is important on this particular project because the part is attached to a device with silicone adhesive and it creates a strong sealing bond.  I tried this with .2 Final and it creates the bottom shell and perimeters with NO infill.  I had to go back to  .1 to get the job done so I didn't get a screen shot of  the .2 Final error.  Here are screen shots of the settings I use and a screen shot of the part sliced in 1.41.1.  I also included the STL file doe the part.  Could someone try slicing  the file with on your PC with .2 Final and see if your results are any better please.  I'd like to verify whether it's .2 Final or just my installation.  By the way I tried other infills than just Gyroid and it made no difference.
Thanks Gary
Mechanical Design since June 1973 3D Printing since November 2016 😀
