Rough edges
Phil
 Phil
(@phil-4)
Rough edges
Any idea what could be causing this? I've had the printer for about 3 months now. When I first got it, I feel like the sides of an object were much smoother than they are now. That could be perception, but if I look at my first benchy printed in Prusa Silver, it looks better than this. You will see in the picture below that they are a very rough. I got the printer assembled.
Any thoughts
Posted : 01/10/2018 3:38 pm
RufusClupea
(@rufusclupea)
Re: Rough edges
Could be a maintenance issue. I think I'd start by looking at belts & bearings. Depending on usage, 3 months may/may not be long enough to warrant some adjustment/tuning.
prusa mk3 maintenance
That's "MISTER Old Fart" to you!
Posted : 01/10/2018 4:15 pm
toby.k
(@toby-k)
Re: Rough edges
I assume that's PLA ..
If you've already tried a different filament and have the same results, try running at a lower speed on the cooling fan...the new "Dyson style"/R3 fan nozzle is really pretty effective. I know that most PLAs like a lot of cooling, but just for chuckles, try 75% instead of 100%. If it looks better, then try something a little lower.
Also, you might want to run the XYZ calibration and then check what the belt status numbers are and that they are within spec.
Posted : 01/10/2018 7:26 pm
Phil
 Phil
(@phil-4)
Re: Rough edges
thanks everyone. I tightened the belts, oiled the rods, and switched filaments. Things look much better. the belts and bearings helped, but it wasn't until I switched filament that I feel it went away completely. Oddly, it seems to be specific to that filament. Perhaps I need to try drying it out.
Posted : 02/10/2018 11:55 pm
robbert.g
(@robbert-g)
Re: Rough edges
Looks like overextruding to me.
I use a filament for which I have to set the extrusion multiplier to 0.91 (even lower than the Prusa setting of 0.95).
Posted : 03/10/2018 11:28 pm
