RigidInk PLA profiles
john.m7
(@john-m7)
Hi
Does anyone have any SLicrPE profiles for RigidInks PLAs - I'm playing with various temperature settings as I've had some odd artificts and obviusly RI are very hot on using lower settings - anyone had good consistant results with what temperatures ?
Thanks
J.
Opublikowany : 06/08/2018 11:20 am
RufusClupea
(@rufusclupea)
Re: RigidInk PLA profiles
When trying new/different filament, the first thing some folks print is a temperature tower, which can help you zero in on the best settings for your individual printer for that filament.
using a temperature tower
Hope this helps.
That's "MISTER Old Fart" to you!
Opublikowany : 06/08/2018 1:02 pm
christopher.o3
(@christopher-o3)
I've been using Rigid Ink PLA for a while. I usually use 210 first layer, 205 for the rest of print, with 60c bed.
Opublikowany : 06/08/2018 1:48 pm
You might find some useful info in this thread. Rigid.ink materials can apparently be printed at lower-than-typical temperatures for PLA. I've had no issues using higher (~205C) temps, but you may get better results at cooler temps.
Opublikowany : 06/08/2018 3:16 pm
Martin Wolfe
(@martin-wolfe)
Here is my profile for Rigid Ink PLA.
Extruder 180/180
Bed 45/45
Fan 100% - disabled for the first layer
The following is added into Printer settings/custom G-Code before the extruder temperature is set to enable printing below 190C
M302 S170 ; Sets the minimum extrusion temp to 170C
Regards,
Martin
Martin Wolfe
Opublikowany : 07/08/2018 11:48 pm
