RigidInk PLA profiles
Hi
Does anyone have any SLicrPE profiles for RigidInks PLAs - I'm playing with various temperature settings as I've had some odd artificts and obviusly RI are very hot on using lower settings - anyone had good consistant results with what temperatures ?
Thanks
J.
Re: RigidInk PLA profiles
When trying new/different filament, the first thing some folks print is a temperature tower, which can help you zero in on the best settings for your individual printer for that filament.
Hope this helps.
That's "MISTER Old Fart" to you!
I've been using Rigid Ink PLA for a while. I usually use 210 first layer, 205 for the rest of print, with 60c bed.
You might find some useful info in this thread. Rigid.ink materials can apparently be printed at lower-than-typical temperatures for PLA. I've had no issues using higher (~205C) temps, but you may get better results at cooler temps.
Here is my profile for Rigid Ink PLA.
Extruder 180/180
Bed 45/45
Fan 100% - disabled for the first layer
The following is added into Printer settings/custom G-Code before the extruder temperature is set to enable printing below 190C
M302 S170 ; Sets the minimum extrusion temp to 170C
Regards,
Martin
Martin Wolfe
