Rhythmic popping sound
BMet
 BMet
(@bmet)
I'm hearing a popping sound while my project is printing the top layers.  Any ideas what it might be?  I've attached a video where you can hear it (at least I hope this video attaches correctly).  I guess not.  It must be too big.
Questa discussione è stata modificata 5 years fa da BMet
Postato : 19/08/2021 8:54 am
BMet
 BMet
(@bmet)
Link to video (I hope)
https://drive.google.com/file/d/1RDDds8TnzaHe3SG5V1yWoDHKLKbEqFhg/view?usp=sharing
Postato : 19/08/2021 9:04 am
Utenti
Odd sound
Does it happen with all layers of print or just the 100% infilled layers?
Postato : 19/08/2021 10:00 am
BMet
 BMet
(@bmet)
Popping
I don't remember hearing it at all until this last print when I was monitoring the final 4 top layers.  And I don't hear it right now when starting a new print.
Postato : 19/08/2021 10:32 am
Possible extruder flow issue
If you are referring to that soft thumping sound, that is likely caused by back pressure in the extruder. Observe the print to see if that only happens when doing large solid infill areas like it's doing in your video. Infill is printed at a higher rate of speed, and overrunning the hotend throughput rate (max volumetric rate) is common.
This is easy to test. Next time that noise starts, dial back the speed to 50% using the front knob on the printer. If the thumping or clicking subsides, you know it's just a question of speed.
  • If it's not causing print defects, you can ignore it.
  • Bumping temps up 5-10C can improve flow, but might add to stringing and other issues.
  • You can reduce the infill speeds, or just set Filament Settings->Advanced->Max volumetric speed 1-2 mm^3/s lower and try again.
Postato : 19/08/2021 2:46 pm
BMet
 BMet
(@bmet)
Possible Extruder flow issue
Thank you.  It doesn't appear to have quality issues so I think I'll take your advice and ignore it.  One less thing to worry about.
Postato : 19/08/2021 6:05 pm
