Prusa Belt Tension App for MK3S+ ?
For MK4 and XL Prusa make app for tension belt: https://prusa.io/belt-tuner it be grat to have it for MK3S+ and MINI+ !
RE: Prusa Belt Tension App for MK3S+ ?
I'd say this works on mk3 if you select mk4
I would suggest that this is effective for the mk3 if you choose the mk4 option.
Greg Saunier originated this technique, and you can find instructions and a link to a more generalized app in his assembly guides for the Bear Extruder and X-Axis, and the Bear frame upgrade:
https://guides.bear-lab.com/Guide/5.+Final+adjustments+and+calibration/38?lang=en#s566
Thanks
