Problem with new Printer parts R3 "Better cooling and extruder upgrade"
christoph.b9
(@christoph-b9)
Hello,
I have some problems with the new printer parts from the New Kit "Better cooling and extruder upgrade":
1. There is no grid between the heatsink and the wire for the probe and fan. I think that could be danger.
2. There is no connection from one of the both holes of the fan to the extrudor --> The fan is not fixed!
3. The screw of the other hole of the fan fits in the hole of the nozzle-fan-support, but does not hold.
Do you have the same problems? Are any solutions or instructions available?
Best regards
Christoph
Napsal : 22/07/2018 2:43 pm
ClassicGOD
(@classicgod)
Re: Problem with new Printer parts R3 "Better cooling and extruder upgrade"
@1 The grill was removed on purpose to reduce the airflow resistance, the heatsink does not heat up enough to damage the wire so there is no danger there.
@2 Correct. If you mount fan at 45 degrees you use only 1 screw. The second one is there if you prefer the old fan layout.
@3 Have you inserted a nut into the hole on the other side?
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Napsal : 22/07/2018 2:55 pm
christoph.b9
(@christoph-b9)
I forgot the nut! Now the screw holds into hole!
Thank you for your fast replay! Now I trie it out 🙂
Napsal : 22/07/2018 3:08 pm
ronnie12342003
(@ronnie12342003)
I printed this update and downloaded the latest firmware its bloomin brilliant now thanks joe just need my textured bed and ill be whole again lol
Napsal : 22/07/2018 10:17 pm
ed
 ed
(@ed-3)
I left a few cm of slack in all of my wires when I re-did mine. The first time around I had everything a bit tight then ended up with a lot of excess wiring stuffed in the einsy housing. This time around I figured a little slack might not be bad.
Napsal : 22/07/2018 11:50 pm
MTJC
 MTJC
(@mtjc)
What do you mean exactly? Blooming brilliant compared to before in what way?
Napsal : 04/08/2018 11:20 pm
ronnie12342003
(@ronnie12342003)
cooling is so much better and changing the ptfe tube is easier to replace also you can get at it better
Napsal : 06/08/2018 9:59 pm
