Printing issue with 3DLabprint airplane
BorisK
(@borisk)
Hi
I use Prusa i3 MK3 and I must tell, that I am very satisfied with this 3d printer. I buy gcode on 3DLabprint and I print complete Sptifire MkIX without biger problems. I use original Gcode. Now I start to print second airplane and this is Cesna 152. I finish 75% of parts, now I stuck on some point. My prints are dropped from hotbed because nozle crash in to prints. I find where print start rolling up and where nozle hit and drop my parts from hotbed. Otherway print are OK (you can see on pictures) It happend all the time and I can not print anything. Please see attached pictures.
Anybody with same experience or some idea how to solve this problem?
Publié : 25/10/2018 10:46 pm
Patrick McNamara
(@patrick-mcnamara)
Re: Printing issue with 3DLabprint airplane
I solved the problem by turning on "nozzle wipe". The default 2mm in Simplify 3d seemed to work fine. Also set "only wipe for outer most perimeters" to no and "perform retract during wipe" to yes. I don't know if the "wipe while retracting" setting in Slice3R will do the equivalent. Not sure what the equivalent setting in Cura is.
Publié : 26/10/2018 3:43 am
robert.t17
(@robert-t17)
I had the same problem and solved it in S3D the same way.
Publié : 26/10/2018 1:03 pm
BorisK
(@borisk)
Thank you for your answers. Can this be done somehow to be implemented in the original code?
Publié : 26/10/2018 4:47 pm
