Printing Issue - Not correct .
Abdulrazaq
(@abdulrazaq)
Hi Guys ,
I have an issue during printing as the print isn't clear, as I faced this issue after I print one object and for somehow all the feliment gathered under the nozzle, since that time I have an issue with printing , please check the below video .
Best Regards
Abdulrazaq
Best Answer by JoanTabb:
You are using a complex gcode to address a simple issue,
I suggest that you get the centre of the build plate sorted first, than try this complex pattern again
the Prusa first layer configuration tool is difficult to perfect, so I use the 'Life Adjust Z My Way' option
Postato : 01/02/2021 6:39 pm
Dan Rogers
(@dan-rogers)
RE: Printing Issue - Not correct .
Does look like failure in first layer bed adhesion.
If your printer still has the build-up of plastic stuck all over the bottom of the print head, you will need to remedy that.  It has happened to me at times when I do not monitor the first layer (you can save a print that is having adhesion issues using feature called Live-Z) - it is a risky practice to start a print and walk away - the melted plastic mess is often the consequence of start-print-walk-away.
I use long nose pliers - tiny ones - and magnifying lens to see details (do not break the fine wires near the nozzle.)
Postato : 02/02/2021 7:29 pm
Abdulrazaq
(@abdulrazaq)
I have try to clean the nozzle, but no result, as I have same issue.
Postato : 17/02/2021 4:12 am
Peter M
(@peter-m)
To print you need to get2 things 100% good.
1. clean bed, use dish soap, use hot water, and use a lot of water, clean a few times.9always print immediately to dry the steel plate it will rust).
2. First layer needs to be 100%.
If it fails with me, this is what I do.
print 8 squares on the bed,
start printing,
start the first layer calibration to high, and lower it slowly, and change with every square9or smaller),
then you have a few squares and look for the best one.
To low is not good model will release, to high the same.
I think you need to go lower a little, but start higher to be safe.
If all works you need to clean with dish soap, and a few prints you can use alcohol, but then you need to use dish soap again.
Clean with alcohol, use  a lot of alcohol.
Always use a new paper towel.
Only a little finger print will destroy your printing by releasing the model.
Use glue stick is possible if needed, I do alcohol on bed, then I use the glue stick to get a thin layer.
And read the forum, these tips you could find on the forum.(and find new things, get user tips).
Postato : 17/02/2021 12:14 pm
Abdulrazaq
(@abdulrazaq)
Thank you Peter ,
I have followed your steps but until know I didn't clean it with alcohol yet, but I got good result .
dish soap is resolve some if issues, as right now at least I can print 😀 .
Still I have an issue with point 2, as I tried to adjust the Z , but still failing 😫 ,
Postato : 26/02/2021 7:47 am
Postato : 26/02/2021 11:36 am
Utenti
@abdulrazaq
Your Z appears too high.
Postato : 26/02/2021 11:42 am
Peter M
(@peter-m)
Start printing,
start the first layer calibration to high, and lower it slowly, and change with every square or part of square.
And make a picture that we can zoom in on to see the layer better.
Postato : 26/02/2021 2:27 pm
Abdulrazaq
(@abdulrazaq)
Thank. you guys, I have did 'Life Adjust Z' which solve the issue, but I'm still looking for the better 🤩 , as right now the print is perfect 👍 , but I notice that there are some lines are not ok , please check the below
Postato : 26/02/2021 9:36 pm
