Print Issue Need pointers
Justin Ingram
(@justin-ingram)
Hello all, We have a MK3s+ and have recently started having an issue with the printer like the attached picture and eventually crashing. The screen gives the option to restart print or cancel print. Before this issue occurred the filament got jammed in the hot end and I had to remove the plastic tube and remove the filament that was in there. Any help would be appreciated. Thank you, Justin
Napsal : 03/10/2022 2:33 pm
RE: Print Issue Need pointers
I am not sure that you asking but I think you are saying the blob cause your printer to crash and you are asking for advice on how to adjust to it?
I would hit continue print.  If it happens again, remove the print and restart,
Napsal : 03/10/2022 5:09 pm
mtmud
(@mtmud)
I know this won't be a lot of help, but I am having the same issue.  I assumed that the crash was the problem, but figured out that when the blobs cool and the print head hits them, it causes the crash.  At least figuring this out has helped eliminate a few things like the drive system.
Napsal : 03/10/2022 8:27 pm
mtmud
(@mtmud)
Justin,
I was having the same issue and ended up doing a thorough cleaning of the nozzle and a first layer calibration.  This fixed my issue.
Napsal : 04/10/2022 1:59 am
