post processing drill bits
Matt
 Matt
(@matt-4)
According to the instructions to upgrade the MK3S to the + version I need the following:
[Twist drill bits, ideally with a flat head, but those aren't easy to find. The lower the angle on the bit's head the better. For printed parts you need two sizes: 8.1 mm / 0.3-inch drill bit (or slightly bigger, but not smaller) 3 mm / 0.12-inch drill bit (or slightly bigger, but not smaller)]
What drill bits are people using in the USA?  Why are these so difficult to come by? I have a full SAE drill bit set, which ones am I supposed to use?
Thanks!
Respondido : 31/08/2021 6:14 am
I am not aware of that requirement but perhaps this is a recent change.  Prusa usually supply all necessary tools...
Please provide a link to the instructions you are following.
Respondido : 31/08/2021 10:49 am
John
 John
(@john-6)
You could try https://www.mcmaster.com/drill-bits/system-of-measurement~metric/
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Respondido : 31/08/2021 10:45 pm
Swiss_Cheese
(@swiss_cheese)
many things are becoming increasingly difficult, or more expensive to find here in the US.
Good Luck
Swiss_Cheese
The Filament Whisperer
Respondido : 01/09/2021 1:58 am
1 les gusta
Matt
 Matt
(@matt-4)
https://help.prusa3d.com/en/guide/how-to-post-process-the-printed-parts_18680
Respondido : 01/09/2021 3:06 am
laserist
(@laserist)
You can always grind the point off...
Respondido : 01/09/2021 1:29 pm
Ah yes, I'd forgotten. I have a wide range of similar tools so just reaching for the item doesn't stick in the memory...  When I last printed a replacement X idler housing I used a reamer.
If you cant get conventional flat-point drill bits try an auger style wood bit - there will be a little spike at the end which can be snapped or ground off.
Respondido : 01/09/2021 5:10 pm
