Original Prusa Drivers & Apps - 2.2.3
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
UPDATE: A new version is out, solving the issue with the digital signature https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/original-prusa-drivers-apps-2-2-5-t28597.html#p135089
Hi guys,
here you can find the newest release of drivers and software for Original Prusa i3 printers. Included is the latest stable release of Slic3r Prusa Edition with integrated firmware updater and many more!
What is new in this release:
Added support for new printers
Support for MK2.5, MK3S and MMU2S (including sample objects)
New Slic3r PE v1.41.3
- Printer profiles for new printer variants - MK2.5S, MK3S, MMU2S
- Updated Configuration Wizard (Assistant) GUI
Supported printers:
Original Prusa i3 MK3S (new)
Original Prusa i3 MK3S MMU2S (new)
Original Prusa i3 MK2.5S (new)
Original Prusa i3 MK2.5S MMU2S (new)
Original Prusa i3 MK3 MMU2
Original Prusa i3 MK2.5 MMU2
Original Prusa i3 MK2/S
Original Prusa i3 MK2/S MMU1
Supported platforms:
Microsoft Windows
macOS
Linux (see Appimage on Github)
Download link:
http://www.prusa3d.com/drivers
Looking forward to your feedback! Happy printing 😉
Assembly manuals
/ Knowledge Base
Postato : 19/02/2019 1:46 pm
Sembazuru
(@sembazuru)
Re: Original Prusa Drivers & Apps - 2.2.3
Are the new profiles (including the speed and quality profiles) going to be ported over to whatever repository the Slic3r 1.42 alpha checks? I got a profile update last night on my alpha5 install, but it was only SL1 profile updates.
See my (limited) designs on:
Postato : 19/02/2019 6:59 pm
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
Hi Christopher,
as soon as development of 1.42 is finished, the settings should be included as well. The new Quality and Speed profiles are here to stay 😉
Assembly manuals
/ Knowledge Base
Postato : 20/02/2019 11:04 am
Sembazuru
(@sembazuru)
Hi Christopher,
Thank you for your response.
It would be nice to get the new permanent Quality and Speed profiles in the alpha sooner rather than later. Speaking as someone who regularly uses the alphas instead of the stable previous release. (I've gotten used to the new workflows, and the bugs aren't bad enough for me to be concerned. Especially since this is just a hobby, nothing I do on my printer is mission critical.)
Postato : 21/02/2019 8:20 pm
Spacemarine
(@spacemarine)
I second that!
It would make sense to include the new profiles as early as possible in the alpha to have people test them.
Postato : 24/02/2019 5:34 pm
hdk
 hdk
(@hdk)
The drivers (prusa3d_win_2_2_3.exe) are NOT signed. I checked version 2.2.2 and drivers are signed.
Please verify the posted exe and correct it ASAP.
Postato : 09/03/2019 11:44 pm
Leeft
(@leeft)
i have a problem with the exe file, when i try to install in my pc, win 10 give me this error
the exe file is not signed, can this be the problem?
Postato : 10/03/2019 12:11 pm
hdk
 hdk
(@hdk)
Yes, lack of digital signature is the problem. DO NOT disable UAC to install this version. Grab version 2.2.2 instead from here:
http://prusa3dprinters.vshcdn.net/downloads/drivers/prusa3d_win_2_2_2.exe
(copy and paste the link
There is a slim chance that 2.2.3 has been altered by 3rd party without Prusa Research permission/knowledge.
In all likelihood it was just rushed and someone has skipped a step or posted a wrong file.
Monday is just around the corner. Let's hope someone from Prusa will this thread and correct the exe posted.
Postato : 10/03/2019 8:58 pm
Brebs
(@brebs)
An alternative to get this to install is to use powershell in the Administrator mode. Simply copy the poorly signed build of Slicer to an easy to get to location. Then open up powershell in Administrator mode (Best way to type in the Windows search and let it give you the indexed view). Then you will see a Blue DOS looking window. Simply navigate too the Slicer directory (EG: code d:\apps\slicer.exe) and then this gets around the issue and shoud install.
But in reality the first thing that should alway happen is the signing of the app should be solid. After all this is the first issue you will encounter as an end user on Windows 10 with a signed in account to the cloud.
Postato : 12/03/2019 4:27 am
David H. Brown
(@david-h-brown)
Certificate was revoked. Re: Original Prusa Drivers & Apps - 2.2.3
The problem I'm getting with 2.2.3 is not that it's unsigned... it was signed by "Prusa Research s.r.o." on "‎Tuesday, ‎February ‎12, ‎2019 7:30:18 AM" but the certificate has been revoked by its certification authority, "StartCom Class 3 Object CA." Actually, the StartCom Certification Authority was revoked, apparently these were bad actors, doing things like issuing certs for github, so they were effectively shut down by browsers and OSes refusing to trust their CA roots. See article on Wikipedia.
Prusa, please get yourselves a code signing cert from a trustworthy CA!
https://www.thingiverse.com/davidhbrown/designs
Postato : 13/03/2019 6:58 am
richard.l
(@richard-l)
Utenti Moderator
Re: Certificate was revoked. Re: Original Prusa Drivers & Apps - 2.2.3
This is being handled by Prusa and they should have a properly signed package available soon.
Postato : 13/03/2019 3:39 pm
David H. Brown
(@david-h-brown)
Great to hear; thanks for sharing that! (Ironic to encounter this problem on the 30th anniversary of the web, when many articles bemoaned how we can't all behave like the trusting academic types who designed it imagined people would.)
Postato : 13/03/2019 4:00 pm
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
UPDATE:
Guys,
Assembly manuals
/ Knowledge Base
Postato : 25/03/2019 8:49 am
