Need instructions to combine three upgrades
bhalter
(@bhalter)
I have a fully assembled Prusa MK3, an unassembled MMU2 upgrade kit, a MK3 to MK3s upgrade kit, and a MMU2 to MMU2s upgrade kit. I want to assemble, and install all three of the upgrade kit, but, all three kits have parts to upgrade the extruder, idler, and pulley assemblies, and the electronics.
I have instructions to do these three upgrades separately, but I can't find instructions to combine all three upgrades. Does anyone know where I can find instructions to combine all three upgrades, so I know which items I should use and which ones I should leave out, and what order I should put the remaining parts together?
Posted : 30/10/2019 5:10 pm
RE: Need instructions to combine three upgrades
Upgrade the printer by itself; get it working to your satisfaction. The new IR filament sensor design has issues; and the new extruder design has issues - make sure you are using the latest extruder parts.
Once the printer is back together and usable - including an operating filament sensor - then and only then add the MMU/s.  Otherwise - if there is a problem - you will not have a clue what is going wrong with the pair.  Best to have at least one thing in a known working condition before paring them up.
Posted : 30/10/2019 8:32 pm
bhalter
(@bhalter)
when you refer to the "latest extruder parts", are they the ones included in  the "Original Prusa i3 MK3 to MK3S upgrade kit", or are there other ones, I should use? Also, are there any instruction online on how to fix the "new IR filament sensor  issues?
thanks
Posted : 11/11/2019 3:08 pm
