Need help with calibration xyz after assembling kit.
mkalel
(@mkalel)
Hello,
i just bought i3 Mk3S . After I assembled it, I was having problem with calibrating XYZ and finally somehow I was able to fix it and able to print my first print from SD ( PURSA ) logo. When I went for the send print Batman. I again encounter with this problem (some problem encountered Z - leveling enforced ) . I tried to re calibrate it and start from the beginning , now its not even calibrating .while calibrating  Its successfully found all 4 points ( corner ) . But the mesh bed leveling is having issue . Should I move the probe sensor because I tried  couple of times and its not working.
any suggestions
Publié : 31/03/2022 9:13 pm
RE: Need help with calibration xyz after assembling kit.
in what way is mesh bed levelling not working?
I use 7x7 mesh bed levelling (Accessivle vis the LCD Menu)
and I use a different Live Z adjustment procedure. I use 'Life adjust Z My Way
these may help you resolve your issues. regards Joan
Publié : 31/03/2022 10:13 pm
1 personnes ont aimé
