MK3S upgrade instructions
JMcK
 JMcK
(@jmck)
Are the MK3->MK3S instructions posted?
Not seeing them on the support site...
When someone asks you if you're a god, you say, "YES!"
Opublikowany : 14/02/2019 2:19 am
kirby polubić
imod.systems
(@imod-systems)
Re: MK3S upgrade instructions
I know the MK3S instructions are posted. You could just use the extruder chapter for the MK3S.
Opublikowany : 14/02/2019 2:50 am
keithywhites
(@keithywhites)
here https://manual.prusa3d.com/Guide/5.+E-axis+assembly/1055?lang=en
Opublikowany : 14/02/2019 2:56 am
JMcK
 JMcK
(@jmck)
Yea, I was also wondering if the upgrade path also included printing/installing y-axis belt holders, heatbed cable holder, Einsy case... ( Nice, but optional, in my view...)
The new e-axis assembly implies that MK3S hot ends are different with the caution to look for an orange dot. Clearly for $20 a new hot end is not needed. So how does that reconcile?
Nothing earth shattering, just some points of clarification that docs would be expected to clear up.
Opublikowany : 14/02/2019 12:00 pm
GeorgeE
(@georgee)
I've guessing there must have been some 12V hotends that have managed to work their way out to customers and the orange dot is just to identify the hotend as 24V. If you are upgrading a working printer the assumption would be your hotend is ok to use.
Opublikowany : 15/02/2019 12:34 am
vintagepc
(@vintagepc)
I think the dots are for the lengths of PTFE tube. MMU2-ready ones had a green dot because the PTFE was shaped differently. Reports say it's also shorter for the Mk3S by a few mm, so they probably orange-dot it if it has the shorter PTFE installed.
Opublikowany : 15/02/2019 1:17 am
JMcK
 JMcK
(@jmck)
Proved my point. Speculation that proper docs would clarify instantly.
Opublikowany : 15/02/2019 2:06 am
Paul_Wilts
(@paul_wilts)
There is also more to the upgrade than assembling the new extruder. How much of our existing Mk3 do we have to disassemble and in what order? For example it looks like we will have to unwrap the cables to fit a new sensor cable as the filament sensor have different cables. Having ordered the upgrade, from an R3 machine built a month ago, I am wondering if the hassle of disassembly will be worth it. I’ll probably wait until some results are posted.
Opublikowany : 15/02/2019 1:42 pm
Markus_D
(@markus_d)
Hey Guys,
sorry for my dumb question. But where can I get the .stl Files to upgrade to Mk3S?
I didnt find anything by myself. Maybe One of you can post a link.
THX for your Help
Have a nice day
Opublikowany : 17/02/2019 7:47 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
https://www.prusa3d.com/downloads/others/mk3-mk3s-upgrade.zip#_ga=2.241938882.1991240978.1550088028-314787885.1542203104
print them in PETG this is the full plate of them as printed
Opublikowany : 17/02/2019 10:05 pm
Geekdad_3D
(@geekdad_3d)
RE: MK3S upgrade instructions
Here are the upgrade specific instructions.
https://manual.prusa3d.com/c/Original_Prusa_i3_MK3_to_MK3S_upgrade
Opublikowany : 28/05/2019 1:13 am
kirby polubić
