MK3 Layer shift problem
karim.b2
(@karim-b2)
I had this printer since Feb 2018 and had my share of problems, some I was able to solve. I have my filament sensor turn off. I am having print stop in the middle of a print and layer shift. I am using firmware 3.2.1. and the latest prusa control. please see attach Photo below.
Thank You.
Napsal : 12/07/2018 11:11 pm
1_mg_1
(@1_mg_1)
Re: MK3 Layer shift problem
One possibility is your X axis belt is too loose and it skipped a tooth. That is a significant layer shift. Also make sure your x axis idler pulley can spin freely and isn't binding up.
Napsal : 12/07/2018 11:26 pm
Hi Karim,
may I suggest that you update to the latest drivers
and then use the new Slic3r to update to the latest Firmware
https://www.prusa3d.com/drivers/
Napsal : 13/07/2018 3:45 am
bernhard.b
(@bernhard-b)
I also had a layer shift with the latest firmware.
Napsal : 16/07/2018 5:24 pm
karim.b2
(@karim-b2)
ok so I update to latest firmware 3.3.1 and no more layer shift. I did not adjusted the belt on X axis. The printed model below was printed with prusa slic3r at .2mm layer height and Hatchbox filament.
Napsal : 20/07/2018 5:21 pm
karim.b2
(@karim-b2)
Napsal : 20/07/2018 5:22 pm
