MK3 Layer shift problem
I had this printer since Feb 2018 and had my share of problems, some I was able to solve. I have my filament sensor turn off. I am having print stop in the middle of a print and layer shift. I am using firmware 3.2.1. and the latest prusa control. please see attach Photo below.
Thank You.
Re: MK3 Layer shift problem
One possibility is your X axis belt is too loose and it skipped a tooth. That is a significant layer shift. Also make sure your x axis idler pulley can spin freely and isn't binding up.
Hi Karim,
may I suggest that you update to the latest drivers
and then use the new Slic3r to update to the latest Firmware
https://www.prusa3d.com/drivers/
I also had a layer shift with the latest firmware.
