Missing STEP files in Original-Prusa-i3 github repo
Otso
 Otso
(@otso)
I noticed that not all parts in https://github.com/prusa3d/Original-Prusa-i3/tree/MK3S/Printed-Parts are available as STEP files that have counter parts as STL. Is this deliberate or have they been forgotten? I'd prefer to use the STEP files as reference when I make modifications or additions to my printer.
There's also at least one (over a year old) unresolved issue in github related to this: https://github.com/prusa3d/Original-Prusa-i3/issues/188
(It's not just the X axis files that are missing, unlike what the bug report says).
As a side note, the repo "About" says "Original Prusa i3 MK2 3D printer printed parts." which is outdated information.
Postato : 14/01/2024 11:19 am
Otso
 Otso
(@otso)
RE: Missing STEP files in Original-Prusa-i3 github repo
Ok, I found the answer, https://help.prusa3d.com/article/printable-parts-for-original-prusa_1824:
Some parts were designed using OpenSCAD, where SCAD files are the project files you can edit. For that reason, for all parts designed with OpenSCAD, there are only SCAD files and no STEP-files available.
Postato : 14/01/2024 11:47 am
AIui, in the early days the CAD software used (OpenSCAD) did not output STEP.  At some point they switched to STEP capable CAD and parts created/modified after that date have offered the format.
Postato : 14/01/2024 1:32 pm
Windowlick3r
(@windowlick3r)
Utenti
So can someone recommend a good app to make modifications to STEP files (prefer free) and then convert them to STL?
Postato : 29/01/2024 9:56 pm
Otso
 Otso
(@otso)
Posted by: @windowlick3r
I haven't tried it myself, but you can open the OpenSCAD files in FreeCAD and export to STEP from there: https://wiki.freecad.org/Import_OpenSCAD_code
For my use I found an Prusa Mk3 assembly on GrabCAD I used the parts from that model.
Postato : 31/01/2024 8:46 pm
