M92 Stepper Motor Calibration --HOW
David Tan
(@david-tan)
I printed 20x20 test cube and the print was off-measurement.
On my other 3D Printer I would connect them to a Repetier server and in it there's a console that lets me send G-Code commands:
M501 (display current settings)
M92 (enter new parameter for each stepper motor)
M500 (save new parameters)
On the Prusa i3Mk3 I couldn't seem to connect it properly to Repetier. Repetier sees it (USB-to-serial port becomes available) but couldn't establish a working connection to the point I can use the console.
Please help pointing me in the right direction. I'm printing technical parts that requires some degree of accuracy: screw holes, bearing seat block and such where 0.1mm difference matters.
By the way, I think there's a way to send g-code in Prusa Slicer but that's not going to work for my purposes. I need an interactive console to let me read values of stepper motor parameters, change & save.
Thanks.
Veröffentlicht : 05/04/2021 7:39 am
RE: M92 Stepper Motor Calibration --HOW
Posted by: @david-tan
Thanks.
Hello and welcome to the Prusaforum!
With Pronterface this works quite well. Just connect the printer to your PC via USB and start Pronterface.
https://help.prusa3d.com/en/article/pronterface-and-usb-cable_2222
Veröffentlicht : 05/04/2021 1:35 pm
egar
 egar
(@egar)
I found this site helpful - https://weitling.info/d3p/index.php
At the top of the page you can switch between XYZ Calibration and Extruder Calibration.
Veröffentlicht : 05/04/2021 1:44 pm
And here also some small helpful tools: https://blog.prusaprinters.org/calculator_3416/
Veröffentlicht : 05/04/2021 1:50 pm
David Tan
(@david-tan)
@karl-herbert
Thanks for the reply. Though it seems promising, I have yet to try downloading & installing it on a PC --my main working machine is a Macbook-- as current version of Pronter Face doesn't support 64-bit Mac OS (Catalina).
Veröffentlicht : 08/04/2021 4:16 am
FWIW - OctoPrint works well for accessing the printer console. (Also on a Mac.)
Veröffentlicht : 08/04/2021 4:33 am
@david-tan
I have set up a small Lenovo Linux laptop (64-bit) for my printers. I use it to run all applications related to the 3D printer (PrusaSlicer, python, bashscripts for Pi-Octoprint, changing/compiling/flashing firmware, etc.).
Veröffentlicht : 08/04/2021 11:35 am
Martin_au
(@martin_au)
https://www.cartesiancreations.com.au/why-you-shouldnt-calibrate-your-3d-printer/
My advice: calibrate flow/extrusion multiplier only. The default steps are correct.
Veröffentlicht : 09/04/2021 11:28 pm
