Likely cause of slow oozing around nozzle?
buckeyestargazer
(@buckeyestargazer)
I am getting a little bit of filament oozing out around the nozzle at the point where the nozzle threads into the silver heat block.  It's not much, but after a 6hr print there's enough there that gives me cause for concern.  At rare times a little bit of that has come off onto the current print.
What is the likely cause of this?
Opublikowany : 28/09/2020 12:34 am
RE: Likely cause of slow oozing around nozzle?
PTFE tubing not fully inserted or heatbreak not correctly inserted.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/leaking-nozzle-heat-block/
Opublikowany : 28/09/2020 6:00 pm
1 ludzie polubili
buckeyestargazer
(@buckeyestargazer)
Thanks.  I think it likely that the heatbreak has untwisted from the nozzle a little.
Opublikowany : 28/09/2020 6:14 pm
