Layer Shift Caused By Modifier Shapes ?
Christopher Rossi
(@christopher-rossi)
I am having a layer shift issue at the same exact spot on my print each time I print regardless of the size of the print. I have overlapping modifier boxes in that spot on the object. The modifiers just change the infill percentage, and the infill amount is the same for each modifier shape. Does something happen to the G-code when modifiers overlap? If not then I have some other issue that needs to be corrected. Thank you.
Postato : 23/12/2023 4:16 pm
