i do not like shinny filaments
toaf
 toaf
(@toaf)
that is all.
Publié : 04/11/2018 8:01 pm
Re: i do not like shinny filaments
Hi Chris,
you're in good company... the laser Filament sensor doesn't like them either Lol...
Joan
Publié : 05/11/2018 2:19 am
toaf
 toaf
(@toaf)
:). i swear something about whatever makes it shiny makes it melt oddly. at least shiny PLA
Publié : 05/11/2018 2:25 am
toaf
 toaf
(@toaf)
think on average shinny PLA needs more heat?
Publié : 05/11/2018 6:16 am
Olef
 Olef
(@olef)
The filament sensor definitely does not line shiny filaments.
Publié : 05/11/2018 7:58 am
toaf
 toaf
(@toaf)
I wonder if they could have used a diffract color light for the sensor, maybe one that doesn't reflect so much
Publié : 05/11/2018 8:14 am
rob.l6
(@rob-l6)
Wouldn't a micro switch be much easier? I think I even read somebody here has already done the mod.
Publié : 05/11/2018 10:03 am
JMcK
 JMcK
(@jmck)
I would think a micro switch with a 1.7 mm throw would be a PITA to get positioned just right. I noticed they did not go with an optical sensor on MMU2. That uses a ball bearing and PINDA, probably more reliable than the optical, but still feels overly complicated. An idler + encoder might do the trick.
When someone asks you if you're a god, you say, "YES!"
Publié : 05/11/2018 12:04 pm
Zcubed
(@zcubed)
There are 3 ball bearing sensor mods on Thingiverse (mine is the Zaribo one) that explore ways to make the laser sensor 100% reliable regardless of filament color or type. I have been having great success with mine.
https://www.thingiverse.com/thing:3091625
https://www.thingiverse.com/thing:3129921
https://www.thingiverse.com/thing:3178706
https://www.thingiverse.com/zcubed/things
Publié : 05/11/2018 11:01 pm
stephen.h14
(@stephen-h14)
A micro switch would not be able to ascertain if the filament is moving, though. That was why they went with an optical sensor.
Publié : 06/11/2018 12:24 am
Peter in Katy
(@peter-in-katy)
Thanks for putting all of these in one place.
I started with the jltx design, but couldn't get my firmware to work. I didn't realize there were 3 instances of the needed change.
I went with the second option and it just worked, but the threaded cap on top was a weak point. After the second one broke, I looked into the first option again. Success!
Both options work wonderfully when built/configured correctly.
Note to anyone considering these: Make sure that anything near the internal bearing (screw, PTFE) is fully seated. That'll screw with ya. Or so I've heard 😀
Next time I work on my extruder, I may try your option. I know I'll have the part printed and ready to go, just in case. 👍
Publié : 06/11/2018 3:55 am
Zcubed
(@zcubed)
Glad to hear you got it working! The credit all goes to jltx for the original design. If you do for the zaribo one I made, you can use the exact same firmware you just compiled and no pesky mini ptfe tube is needed anymore because of the zaribo design.
Publié : 06/11/2018 4:56 am
rob.l6
(@rob-l6)
Well, you can't have everything 😆
Publié : 06/11/2018 5:12 am
Zcubed
(@zcubed)
You can with the bearing indirect sensor mods!
Publié : 06/11/2018 3:26 pm
rob.l6
(@rob-l6)
Show off.
Publié : 07/11/2018 5:32 am
