How to tell the slicer to make fill transitions somewhere else?
Armin
(@armin)
Hi, my goal is to print an even top surface that is as smooth as possible. Unfortunately, one can see the transitions in the top fill, i.e. where the print head interrupts the fill pattern and continues at another point, especially with silks.
I now have a symmetric object and I'm wondering how to tell the slicer to make these transition from the top fill in the middle and not somewhere in the surface?
Anyone an idea?
Thanks...
Best Answer by FoxRun3D:
Sometimes you can keep the modifiers from "merging" buy just making them slightly different. Eg a small difference in infill pattern or extrusion width, not enough to be noticeable.  But at least in my hands it's been try and error to see what works.
This topic was modified před 3 years 2 times by Armin
Napsal : 16/02/2023 4:41 pm
Silks are designed to expand a little and close gaps but in consequence the surface can be uneven; and, have you dried that filament?
If the cosmetic finish is important then sand, fill and paint.  Take care to hand sand at low speeds so the part does not overheat and distort.
Napsal : 16/02/2023 6:29 pm
RandyM9
(@randym9)
RE: How to tell the slicer to make fill transitions somewhere else?
You can try changing the infill angle in the slicer and you can try different top infill patterns.
It takes some experimenting and ‘you can’t always get what you want…’ as the song says. Sometimes the slicer just has a mind of its own.
Cheers
Napsal : 16/02/2023 9:45 pm
Armin
(@armin)
Thanks for your proposals!
Unfortunately a post processing is not possible (increasing costs) and fill angle, pattern, extrusionwidth and velocity I tried out already. Is there maybe a way to enforce perimeters to split the model visually in two parts? Because then the slicer could create the top fill for each side in one go...
Napsal : 17/02/2023 8:26 am
Jimbo70
(@jimbo70)
I think you are asking for a smooth top layer - please try this setting in Prusa Slicer
infill/ top fill pattern / concentric
the only other possibly I know of is top fill ironing
Napsal : 17/02/2023 4:20 pm
You may be able to do that by using modifiers, depending on the geometry. See attached example
Napsal : 17/02/2023 5:37 pm
Armin
(@armin)
Thanks to all for your hints!
1. Concentric makes symetric pattern but the surface is at the end points not really smooth
2. Ironing makes it smoother but the uniform reflection are lost
3. If I split the objects in 2 modifiers (left, right) and use the same settings (e.g. 1 contour) the Prusa Slicer automatically remove all settings form the modifiers. It only works if the modifiers differs. I know this makes sense, but unfortunately not in my case. Is there maybe a way to switch this of?
Napsal : 19/02/2023 3:40 pm
Napsal : 19/02/2023 4:02 pm
1 lidem se líbí
Armin
(@armin)
Thanks, now it works, and the surface is smooth and has an even reflection on both sides because now the top fill for each side is printed in one go. The perimeters split the top layer of the object visually into two parts, but this looks nicer as the iregularities on the surface. In my case I use pattern monotonic, angle 0° and extrusion width for contours 0,45 (left) and 0,449mm (right).
Napsal : 20/02/2023 9:00 am
Armin
(@armin)
But one can also of course select only the extrusion width of the top fill (left 0.4, right 0.399) and you get a minimum optical transission. The result is much better than usual, especially with silks.
This post was modified před 3 years by Armin
Napsal : 20/02/2023 10:34 am
Great to hear! Would love to see a picture of the final results
Napsal : 20/02/2023 11:19 am
Armin
(@armin)
Unfortunately I can't really catch the light reflection on the photo. But one can see the artificial seam in the middle (at the seam of the circles). Both side looks now evenly smooth without interruption.
Napsal : 22/02/2023 11:27 am
