help with unboxing assembled printer
Phil
 Phil
(@phil-4)
Ok, so I just got the printer and I have the dumbest issue. I can't figure out how I remove the white foam under the nozzle. I'm afraid to turn it on for fear it will move the print head and damage the nozzle.
Publié : 19/07/2018 9:36 pm
DevDoc
(@devdoc)
Re: help with unboxing assembled printer
No need to worry. Just turn it on, and you can go through the menu to settings -->Move Axis-->Move Z and then turn the dial clockwise to raise the print head. A shortcut to this is to wait for the printer to initialize and then hold the dial/button in for 2 seconds and it will bring you right to that option ready to move the z-axis. Hope this helps, and you enjoy your new printer.
Publié : 19/07/2018 9:57 pm
nathan0876
(@nathan0876)
Turn it on.
Hold down the knob for a few seconds until is displays Z : xxxx on the screen(xxxx is a number, yous should be near 0 as its on the plate) Rotating the knob clockwise will rais the Z axis.
Publié : 20/07/2018 9:31 pm
Phil
 Phil
(@phil-4)
Got it. Thanks. As thorough as the manual is, I was surprised this wasn't covered. I see it later, but when I first opened it, it said to cut the zip ties and remove the foam, and then run a calibration.
Printer is running fine now though and as far as I'm concerned the prints look really good.
Publié : 21/07/2018 1:00 am
