Help in putting together a list of spare parts to have on hand, for my MK3 with 189 hours.
KLAUS
(@klaus-3)
Hi I want to get some spare parts ahead of time before a possible break down occurs, for my Mk3.
I am looking to compile a list of parts that; may just need to be replaced due to wear, or  that are most likely to fail, or that I may damage myself some how, or just things to have that I don't know about.
My MK3  has 189 hours on it, I use it often, and if some thing needs to be replaced, I would like to not have to wait for the parts to arrive.
Can you please help me in creating a spare parts list to have on hand.
Items I can order from Prusa's web page.
Items I might order else where.
Items I should print out my self.
Thank you !!
This topic was modified před 6 years by KLAUS
Napsal : 06/07/2020 3:26 am
Peter M
(@peter-m)
RE: Help in putting together a list of spare parts to have on hand, for my MK3 with 189 hours.
Print fan duck in abs, a few extra.
The 2 fans on the extruder.
Cables will break, buy a set extra cables, or solder a new cable between the connectors, i Had to change a fan after 1 year, I disassembled the cables of the extruder, insert the new fan cable, assembled everything, and after a while another cable broke(could be old age or the work of mine), this cable I attached to the outside of the cables cloth, I did not want to damage more cables by disassembling again.
Put every 2 rolls of filament a drop of oil on the rods(first clean the rods), so the bearings move smoothly and do not wear down. Personally i think you do not need to buy bearings.
The 2 sensors on the extruder cab break easily. But are also not easy to remove from hotend heaterblock e3d, i have this block and 2 sensor as a backup.
Napsal : 06/07/2020 4:24 am
1 lidem se líbí
KLAUS
(@klaus-3)
Thanks for that reply,
The printer has 189 days of printing not hours, so just wanted to clarify that.
Anybody have more items for the list?
Napsal : 06/07/2020 6:04 am
KLAUS
(@klaus-3)
Peter are you referring to the hot end thermistor and heater cartridge that go in the hot end block that the nozzel screws into?
Napsal : 06/07/2020 6:52 am
Peter M
(@peter-m)
@bruce-h7
yes, that can get damaged difficult to repair or it is full of filament and not easy to remove.
Napsal : 06/07/2020 8:14 am
RobertusMaximus
(@robertusmaximus)
@peter-m ,
What oil are you using?
Thank you!
Robert
Take my advice and live for a long, long time. Because the maddest thing a man can do in this life is to let himself die. : Miguel de Cervantes Saavedra, Don Quixote ---- Transport Unfriendly…
Napsal : 28/01/2022 5:46 pm
jsw
 jsw
(@jsw)
I'm not Peter, obviously, but I've been using a generic hardware store brand lightweight synthetic machine oil on both the Prusa and the Ultimaker rods.
One drop every so-often works fine.
Napsal : 28/01/2022 6:23 pm
1 lidem se líbí
JustMe3D
(@justme3d)
I have a thermistor for the heatbed, a thermistor for the extruder and a heater cartridge as spare parts available. All three had been replaced once after about 120 days of printing due to wear and tear. Moreover I have the longer of the two toothbelts as a spare (if the shorter one goes dead, I can cut the longer one but not vice versa; and then I have time to get new spares). Then I have a heatbreak, a heaterblock (although the old one was fine to remove and replace the thermistor and cartridge once I had cleaned the screws), some spare tube inserts, a spare filament sensor (as one extra came with the MMU2S), and a used PINDA sensor (as I upgraded to the new SuperPINDA).
I put a finger of BelRay blue waterproof grease every now and then on the moving parts.
Cheers
Chris
Napsal : 28/01/2022 6:39 pm
1 lidem se líbí
Bob
 Bob
(@bob-2)
As well as some of the things others have mentioned, I keep several spare nozzles, spare PTFE tubing, zip ties, PTFE fittings, PTFE jigs, utility knife, spare screws and nuts.
Cheers
-Bob
Napsal : 28/01/2022 9:03 pm
