HELP: Bearing problem?
alexey.g
(@alexey-g)
Hey,
So i don't use my machine for few months becouse of time and now there is strange noises on x and y axis.
the problem always when the extruder go to one side the other ok.
i add video and some print result
https://drive.google.com/file/d/1QdARqV3jj2uXT2azN-d_jFLGn7Azr8Bl/view?usp=sharing
https://drive.google.com/file/d/1HfzX0ajeqbHiOmTRsEy0DFkwyRUgQZGE/view?usp=sharing
Veröffentlicht : 05/11/2018 9:49 pm
Peter M
(@peter-m)
Re: HELP: Bearing problem?
Maintenance?
Clean all rods, then put fresh oil on the rods.(light oil).
Then calibrate the z axis.
Left and right side should reach the top at the same time, if not then the z axis were not level, then normally oil should help.(and z calibration).
Every few weeks you need to clean and put oil on the rods.
Also every month(if you print a lot), check all, yes all bolts and tighten.
Move the extruder with your hand to check if this not lose.
Search with google on maintaining a 3d printer.
And you could do a full calibration, normally not needed.
Veröffentlicht : 08/11/2018 12:03 am
