Getting information from g-code
calvinkwy
(@calvinkwy)
Hi all!
I was wondering if there is any way we can obtain the printing parameters such as infill %, infill patterns,  layers and perimeters etc. from g-code files?
Thank you!
Publié : 12/02/2022 5:45 am
Lichtjaeger
(@lichtjaeger)
RE: Getting information from g-code
With default settings, PrusaSlicer puts a comment block on the bottom of the gcode file containing all the settings used.
Publié : 12/02/2022 8:30 am
Open GCODE in a text editor such as TextEdit on the Mac or Notepad on Windows. Depends on the source of the gcode file if the slicing details are all included. As @lichtjaeger pointed out, if it was sliced with Prusaslicer, you're in luck, they're all at the end of the file. Not as easy to read as loading a 3mf file, that's why we usually ask for 3mf files here to help with troubleshooting.
Publié : 12/02/2022 12:47 pm
1 personnes ont aimé
If the gcode was generated by Prusa Slicer and are in the block mentioned by Lightjaeger  and Fuchsr then you can open Prusa Slicer and use the File>Import>Import Config option and select the gcode file.  It will then load in all the settings it can from the file.
Not as good or complete as the settings stored in a proper PS project file but ok for seeing what was used for most settings.   Of course it does rather depend on which version was used too as older versions didnt store as many settings.
Publié : 12/02/2022 3:33 pm
calvinkwy
(@calvinkwy)
Thanks all for the information! I'm lucky i did it in PrusaSlicer.
Thank you very much!
Publié : 13/02/2022 9:02 am
