Frequent crash while printing
John
 John
(@john-8)
Hi, I print a lot of cylinders for optics, this time the problem was more annoying.
From the photos you can see a vertical seam and in the inside ,some string about
5 to 10 mm further from the seam. After a height of about 30 mm you could tell the
nozzle was bumping over the seam and occasionally giving crash warnings which
I had to over ride to finish. Previously I did a first layer calibration which I thought
looked good. Any idea why this happens? what can I do to fix it? Is the seam normal?
thanks in advance, john
Postato : 20/02/2022 2:52 am
Utenti
RE: Frequent crash while printing
The seam can be normal.  How old is the printer?
Crashing has a lot of causes.  Some are mechanical and others can be due to the nozzle hitting a print such as with warping.
Postato : 20/02/2022 12:23 pm
Bob
 Bob
(@bob-2)
Seams are normal, the print head has to start a layer somewhere so it often starts it at the same point.  Many times this isn't a problem but if it is you can change how the print handles seams.  Take a look at this:
https://help.prusa3d.com/en/article/seam-position_151069/
Cheers
-Bob
Postato : 20/02/2022 2:32 pm
The finish is a little rough, before trying anything mechanical try drying your filament and cutting the print speed by 10%.
Postato : 20/02/2022 2:41 pm
John
 John
(@john-8)
Thanks, that article helped. My concern wasn't so much the seam as the stringing
that occurred on the inside around the same place in the cylinder. I figured it had to
related to the seam even though is was further on.
Postato : 20/02/2022 3:13 pm
