First layer problem occurs very often, can someone explain why this happens?
Dat Concept
(@dat-concept)
Why do these weird spots happen on the first layer?
Opublikowany : 21/04/2022 9:12 pm
RE: First layer problem occurs very often, can someone explain why this happens?
Clean the sheet with hot water and fragrant-free dish washing soap. If the spots disappear, it was fingerprints.
Opublikowany : 21/04/2022 10:05 pm
1 ludzie polubili
Dat Concept
(@dat-concept)
I always clean the bed very good with isopropyl alcohol. But I think it could be a fingerprint thing..., because sometimes there is a string of material across the bed, and I quickly put it it off. I did not now that such a small action could make a difference. Thank you very much for your reply. I am now aware of what could be the problem, so I will try to verify with next prints to see if this is the issue or not. But my gut feeling says it is. Thank you for making me aware. I will let you know if it was the problem. Thank you very much for your kindness and your help, I really appreciate you, thank you !:)
This post was modified 4 years temu by Dat Concept
Opublikowany : 21/04/2022 10:10 pm
Dat Concept
(@dat-concept)
I tested it 🙂 it was indeed from fingerprints. Know I know even the slightest touch will cause this to happen. Thank you very much, I will be much more careful from now on. Thank you so much for your help, because it happened sometimes and sometimes not I did not know what was causing it. But now that I am aware it makes total sense 🙂 thank you once again!
Opublikowany : 21/04/2022 10:43 pm
My pleasure. IPA is good between prints (and you should use lots of it) but every now and then it's time to take the sheets back to the sink for a good scrub because the IPA won't get rid of everything.
Opublikowany : 22/04/2022 1:07 am
1 ludzie polubili
