first layer problem
Simbio3D
(@simbio3d)
first layer problem
what is the correct parameter to fix that problem of 1st  layer?
With PLA I have no problem but PETG gives me those results.
Temperature 250/90 with keros stick
I downloaded those files in gcode but was already set up for the Prusa as it is part of this kit.
https://www.prusaprinters.org/prints/3673-mmu2s-enclosure
thank's for any hint
Publié : 26/03/2021 12:39 pm
Antonio
(@antonio)
Membre Moderator
RE: first layer problem
in my opinion the first layers are too squished and PETG commonly don't like to be pressed.
try to lift a bit with the live z adjust
I'm not an expert. Ma parlo anche italiano 😉
Publié : 26/03/2021 1:18 pm
Simbio3D
(@simbio3d)
Ok, so it's a matter of changing the setting on the first layer. prusaslicer could do that I presume.
Publié : 27/03/2021 12:55 am
Peter M
(@peter-m)
@simbio3d
No, wen you start printing you need to (fine)adjust the first layer, you need to watch the first lines(and best to look at the finished first layer) to see if you need to adjust. And yes you need to do this on every print.
Publié : 27/03/2021 4:14 am
Antonio
(@antonio)
Membre Moderator
When the print start, go on the lcd menu>tune>live z adjust and you can adjust the gap between bed and nozzle.
Publié : 27/03/2021 6:55 am
Simbio3D
(@simbio3d)
Copy that.
Thank you
Publié : 27/03/2021 11:28 am
