First layer issues - Big build, multiple parts
christian.m23
(@christian-m23)
I have been using the MK3 and really pleased with it but i have just come against a problem.
I am doing say 120 parts on the same build , and getting the first layer down is the problem.
I have ran through the wizard again and also calibrated first layer many many times.
It seems that when it does the boarder around the whole build a part of that even comes up off the tray, then when its around 20 pcs in the tip gets a build up of filament and in turn it just builds up a big mess at the tip.
Anyone give me any advise on this please?
Thanks,
Chris
Napsal : 11/05/2018 9:32 am
christian.m23
(@christian-m23)
Re: First layer issues - Big build, multiple parts
The adhesion seems to be fine X but coming back towards me in Y axis it seems to come from the tray.
As you can see in attached picture even the small close layered bit of the sequence the ends seems to come up when going back and fourth.
Napsal : 11/05/2018 11:11 am
christian.m23
(@christian-m23)
Again,
Cleaned tray added the glue stick - tried to optimise level of first layer - hopeless.
Losing faith fast.
Anyone?
Napsal : 11/05/2018 11:23 am
Knickohr
(@knickohr)
Member Moderator
Have you really checked your z-height ?
I looks like your live-z ist too high. Try to move down in steps of 25µm. But be carefull not touching and scratching the bed with the nozzle.
Thomas
Napsal : 11/05/2018 11:50 am
PJR
 PJR
(@pjr)
Antient Member Moderator
The best test for this is 9 x 20mm calibration squares; one in each corner and one in the centre (basically at each calibration point).
You can then adjust the bed a small amount using the bed level correction on the menu (I think that's still available on the Mk3?)
Peter
Napsal : 11/05/2018 1:06 pm
christian.m23
(@christian-m23)
Hi Peter,
I havnt seen this setting under calibration though will look after this build finishes.
Thanks for your input.
Peter
Peter
Your right Thomas,
I just needed to be a bit more patient with it.
I also was moving the tip up instead of down.
IL just walk away red faced.
I need 10,000 parts doing if anyone fancies helping me out.
I can send STL file and prices.
Get in touch if you want to know more.
kind Regards,
Chris
Napsal : 11/05/2018 1:19 pm
PJR
 PJR
(@pjr)
If you want help printing the parts, then you should add your location to your profile...
Peter
Napsal : 11/05/2018 1:20 pm
christian.m23
(@christian-m23)
Peter
Ok will do now.
Its UK Coventry
Napsal : 11/05/2018 1:23 pm
