First layer callibration
Beverke
(@beverke)
When we start "First Layer Callibration" and he comme's at the 9 point he give's the error " Some probleme encountered, Z-leveling enforced".
What can we do to fix it?
Veröffentlicht : 25/02/2020 11:27 am
airsyspro
(@airsyspro)
RE: First layer callibration
I would guess that your printer is not on a level surface.
Veröffentlicht : 25/02/2020 8:15 pm
rmm200
(@rmm200)
Well actually - the surface does not need to be level.
Otherwise tools like lathes and mills could never be used on board navy ships. The angle is constantly changing.
Scroll down to the bottom of this topic and see if it matches the problem you are seeing:
https://github.com/prusa3d/Prusa-Firmware/issues/1651
Veröffentlicht : 25/02/2020 8:57 pm
airsyspro
(@airsyspro)
My experience has found that if one of the four feet is not touching a firm surface, I would have the same problem as listed above!
Veröffentlicht : 25/02/2020 9:07 pm
rmm200
(@rmm200)
No argument on needing a flat surface. It should not rock. Not a problem that is likely to show up during calibration though.
Veröffentlicht : 25/02/2020 9:16 pm
Posted by: @vb-eddy
Another consideration: Is it possible the surface the printer is on is vibrating? That can throw the calibration off. Putting the printer on a solid floor might be a good quick test.
Veröffentlicht : 25/02/2020 9:51 pm
