First layer aspects.
JanV
 JanV
(@janv-2)
Good-morning,
Why does the first layer give such a varying aspect. This is PLA (Prusament).The print bed is prepared with washing-up liquid (drop of Dreft) and rinsed very well.Certain areas look perfect, others look shiny and smeared. See the photos.
Postato : 28/09/2021 9:35 am
Utenti
Underside
It looks like you dropped a little piece of plastic.  Can you post the underside of that first layer?
Postato : 28/09/2021 9:57 am
JanV
 JanV
(@janv-2)
Underside of object..
Underside after printing.
Postato : 28/09/2021 11:53 am
Dan Rogers
(@dan-rogers)
Z too low, PLA doesn't print well on the textured sheet.
Go with the smooth sheet for PLA.  The textured sheet is a nightmare better suited to stickier filaments.
Wavy like water says your Z is too low in spots.  Have you enabled 7x7 bed mesh leveling in settings - that is how prusa bed leveling works.
Postato : 11/10/2021 9:33 am
JanV
 JanV
(@janv-2)
Solution for the problem...
I have now found the cause of my own problem.
Under the sheet, on the heating plate was a miniscule, barely visible piece of black thin plastic.
The calibration before starting the print gave no error message.
After removal I was able to print good first layers again.
Postato : 12/10/2021 10:10 pm
