Firmware Problem
xumuturo
(@xumuturo)
Firmware Problem
I have a MK3. Everything was working fine, just got done with a print job.
One day I wanted to change filament and when I tell it to unload filament it does not turn the heater on and eventually errors out. When it errors I get garbled characters on the front panel screen. I flashed the correct FW but still does the same thing.
check this great cam sites for free - camsites.me - camgirlsites.net - bestcamsites.me
Respondido : 02/03/2022 9:03 am
First check that all connectors are OK, pull and re-insert to make sure nothing is loose.
If this doesn't fix it contact Prusa Support.
For support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Respondido : 02/03/2022 4:37 pm
