Firmware 3.2.0-RC1 for Original Prusa i3 MK3 and MK2.5
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
UPDATE: there is a newer version available! More here https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64
Hi there,
new version of firmware 3.2.0-RC1 for MK3 and MK2.5 is out! Note this is a test build for advanced users 😉
What is new:
MK3:
- linear advance
- new xyz calibration
- filament sensor function improved
- safety timer
- G-codes for setting temperature correction
- extruder linearity correction
- stealth mode for Z axis
MK2.5:
- linear advance
- safety timer
Supported printers:
This firmware supports Original Prusa i3 MK3 and MK2.5
Download link and description:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.2.0-RC1
Firmware flashing guide:
http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.2/66?lang=en
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Assembly manuals
/ Knowledge Base
Postato : 13/04/2018 10:38 pm
Mike
 Mike
(@mike-8)
Re: Firmware 3.2.0-RC1 for Original Prusa i3 MK3 and MK2.5
nice xyz calibration! Great Job! The Nozzle gets realy close to the Heatbed but in my case - no problem. It does not hit the bed.
1st print is in progress.
Postato : 14/04/2018 11:59 pm
lucas.c3
(@lucas-c3)
This is exciting cant wait to try it.
Postato : 19/04/2018 6:07 pm
thrawn86
(@thrawn86)
MK3:
so far, I'm seeing the most consistent first layers I've ever had with the mk3 after redoing the cali with no correction needed. the display spit out gibberish after completing, but I can't argue with the results.
Postato : 20/04/2018 5:14 am
lucas.c3
(@lucas-c3)
I still cant figure out a "perfect" first layer but Been having great print since the last update. Cant wait to try this out!
Postato : 21/04/2018 7:38 pm
webshadow
(@webshadow)
! STUNNING ! Toplayer (without LA it always looked like crap) and a bug in the display seems to have gone where a single character was "mirrored" to a line it does not belong 😉
Postato : 24/04/2018 1:40 pm
Kamil
(@kamil-3)
I tried this firmware. I have still shift in the layers. Please look at the picture. It seems to be ok when filament sensor and crush detection is off. I will try it again without these features.
Postato : 26/04/2018 9:12 am
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
Hi Kamil,
let me know about the outcome of your testing. Filament sensor, nor the crash detection should be affecting the print quality.
Assembly manuals
/ Knowledge Base
Postato : 27/04/2018 7:38 am
arthur.c2
(@arthur-c2)
I tested this firmware and had layer shift as well.
I saw what happened and that's weird (I already saw that with previous firmwares).
Suddenly I eard the printer do the homing like after a crash detection, I looked and there were no reason at all that it crashed (flat part, no blob, ...).
After the homing, its starts to print again but the layer was shifted, like if the homing was wrong. I waited two layers to be sure it was shifted.
Then I forced against X axis with my hand to produce a crash detection. The printer did the homing again and it restarts printing to the good position.
So, it's like if the printer detects crash for wrong reason, make a bad homing, and a layer shift happens. But if there's a real crash, homing is good and no layer shift.
That's weird because homing is homing, but that's what happened each time I saw a layer shift with severals firmware.
I disabled crash detection and we will see. I let filament sensor on, never had problem with it and I don't see how it could produce layer shift.
Positive point : Linear advance seems to be very nice ! The angles are really good !
Postato : 27/04/2018 10:45 am
lukevanpainting
(@lukevanpainting)
Can you disable the safety timers?
What if I have a FIlament change during the print with M600 and I take more then 15 minute to get to the printer?
Postato : 27/04/2018 9:47 pm
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
The timer is now longer in RC2 (30 min).
Assembly manuals
/ Knowledge Base
Postato : 28/04/2018 11:47 am
Jakub Dolezal
(@jakub-dolezal)
Utenti Admin
Assembly manuals
/ Knowledge Base
Postato : 28/04/2018 11:48 am
Kamil
(@kamil-3)
Sorry for late answer but my print took 36h and I left it at work during the weekend to finish it. Here you have results. I print all without the crash detection. It looks much better, even maybe it is only my experience but the first layer looks much better than before. I agree with previous post that after crash detection the printer, it seems does not back to the same place. Sometimes, it shows crashes without a reason. possible to set less sensitivity of detection?? I had for example 3 crashes on X and 12 on Y. In addition, somebody knows how to improve angle printing? I put support below but I am not very happy with results, pls look at the picture.
Postato : 30/04/2018 9:41 am
