Fire hazard?
WerkRaum
(@werkraum)
Fire hazard?
I have put my printer into a closet with some computer hardware, a switch and a NAS. As the closet is wooden, I am concerned that if the printer somehow catches fire, this would be very dangerous.
What is the general risk for this? I have a smoke detector outside the closet on the ceiling, but of course no sprinkler or something like that. I also installed a IoT temperature sensor that notifies me if the closet reaches more than 45 degrees celsius.
I searched online and could find this here which looks really interesting, but no idea where to actually buy one or how to service it:
http://m.aerosolsuppressionsystem.com/quality-11918068d-server-closet-aerosol-type-fire-extinguisher-aerosol-fire-suppression-system
Any advice here? Does prusa have any experience with failure? Is there an automatic off-switch on high temperatures? Do I worry too much? How real is the danger?
Opublikowany : 15/05/2020 2:39 am
JMcK
 JMcK
(@jmck)
RE: Fire hazard?
Any machine, under the right conditions becomes a smoke machine. You can mitigate, but never eliminate the risks.
Prusas are among the safest printers; you’ve done a lot, but never get complacent. I’d also consider a smoke detector inside that closet. Either a simple wired model or networked model like a Nest, that is, a detector that sets off all the others.
When someone asks you if you're a god, you say, "YES!"
Opublikowany : 16/05/2020 3:29 am
1 ludzie polubili
RE: Fire hazard?
There are videos on YouTube on rigging up a smoke alarm with a digital output linked to a power strip that can be shut off with a digital pin. There are also fire-resistant soft enclosures, but that will introduce heat which can complicate printing.
Opublikowany : 16/05/2020 5:08 am
