Filament Selection Back in the Saddle
Dewey79
(@dewey79)
Hello fellow Prusa owners.  I've had my MK3's parked for over 20 months and just now started printing again.  With time I'm sure there's been changes in filament types and what they can withstand.
  Can someone point me to the best filament advances we can use on the MK3?  I pulled my MK3 out of mothballs, updated the firmware and slicer and it's been printing beautifully.
  For the project I'm making right now I had some Hatchbox ABS as I need strong and non-temperature sensitive filament.  What are the new options?  I see Prusa doesn't have ABS other than off brands, is there a new list that explains what filament types to use for different applications?
  I've reserved my place in line for the XL and hope we can add some additional filaments to use on that printer.  Thank you.
Thank you.
Veröffentlicht : 29/01/2022 11:47 pm
RE: Filament Selection Back in the Saddle
Check out https://help.prusa3d.com/en/materials. It has links to all the different filaments with a boat load of information.
Veröffentlicht : 30/01/2022 12:52 am
jsw
 jsw
(@jsw)
I get a 404 on that link.
Hatchbox is one of my go-to filament brands, but supply has been spotty since the pandemic hit.
Others I have good luck with include Overture, RepRapper, Paramount, IEMAI (sp?), Rohs, 3dFilaments, and (really) most Amazon Basics filaments.
Veröffentlicht : 30/01/2022 3:44 am
Yveske
(@yveske)
This is the correct URL https://help.prusa3d.com/en/materials/ (note the ending slash)
Having problems with bed adhesion every morning...
Veröffentlicht : 30/01/2022 8:42 am
jsw
 jsw
(@jsw)
Looks like there is a stray trailing period on the first URL that I reported as bad.
Veröffentlicht : 30/01/2022 9:44 am
Chicago Keri
(@chicago-keri)
For strong and temperature resistant replacement for ABS, the current rage is for ASA.   ASA tends to be a bit stronger, a bit more temperature resistant, is much more UV resistant, warps less while printing and is generally considered a good replacement for ABS.  It does need a good bed surface and higher printing temperatures than ABS but your MK3 can certainly print ASA well.  I find that a smooth PEI sheet works best as ASA doesn't seem to stick well enough to the textured or satin sheets.  My entire MK3s extruder is printed from ASA and it works well.
Another option is PC, or Polycarbonate.  This is extremely strong and very temperature resistant but is difficult to print needing much higher temperatures. It is also hygroscopic, which can lead to stringing.  I have only made small parts like my MK3s cooling fan shroud with PC, and that took a few tries.
And don't overlook PETG.  PETG is almost as temperature resistant as ABS, is about as strong and is much easier to print with little warping and only moderate temperatures needed.  It sticks to a PEI sheet far too well but works great with a textured or satin sheet.  On the downside, it is hygroscopic and difficult to paint or glue.
Happy Printing!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Veröffentlicht : 30/01/2022 2:05 pm
Dewey79
(@dewey79)
How is the smell and toxic affects compared to ABS?  ABS is real bad and I need to vent it to the outside.
  That's a good point, what filament should be vented to the outside.  PLA and PETG weren't bad as long as I had good ventilation.  What is everyone else doing for smell and health related concerns?
Veröffentlicht : 30/01/2022 4:33 pm
Chicago Keri
(@chicago-keri)
ASA is regarded as a plastic that releases potentially toxic fumes. It seems less smelly to me than ABS.
But that said, all 3D printing should have ventilation! We are heating plastics to the melting point, after all.  It seems that SLA printing is much more toxic though.
I am a bit cautious and do 3D printing near an exhaust fan.  I'm not especially susceptible to fumes as my job environment is pretty toxic with fumes, particles and chemicals so my concern is not noticing buildup of fumes.
Veröffentlicht : 30/01/2022 4:58 pm
