Filament Jammed 3/4's of way down PTFE tube
auto303615
(@auto303615)
Folks,
   Repeat event here.  After few hours of printing my extruder stops extruding.  Filament stops flowing.  If I am near the machine, I hear the clicking of the stepper as it tries to force the filament down the PTFE, but the mass that forms at the bottom of the filament stops all flow.
   I have adjusted the tension on the idler screw that holds the filament gears together.  Any ideas?
This topic was modified před 6 years by auto303615
Napsal : 27/06/2020 4:23 pm
auto303615
(@auto303615)
RE: Filament Jammed 3/4's of way down PTFE tube
Update:  I increased layer size from 0.05 to 0.15 and the print worked without jamming.  No other changes.
What do I have wrong at the lower layer size?
Napsal : 29/06/2020 11:09 am
Try reducing your retraction to say 0.4mm or 0.2mmthis will reduce the amount of hot filament pumped back into the heat break on every retraction
regards joan
Napsal : 29/06/2020 11:54 am
