Experienced eyeballs needed BLC interpretation
Pardon my light box quality.
so, kind of a dish shape, spilling out the back
have not yet been into the lcd menu, posts I read mentioned L/R, F/B settings which wont help here.
first off,
Is this close enough?
I dont have large part issues at all, but have had a a poorly laid out platter of 8 odd shapes STB,
RE: Experienced eyeballs needed BLC interpretation
I'm not really sure what you mean or what you're asking.
From that photo, it's very difficult to get a handle on what the tops of the test squares really look like.
I suggest more of an oblique view photo, right on the build plate, plus a photo of the bottom sides of the test print, particularly if there's significant difference in them.
Right on,
I was focusing on the density, which shows well this way. lemme wipe the peanut butter off the Pixel, and get obliquey
So, the corners, and the middle.
I went into the BLC menu, an yea, that can only tilt a true plane, not fix a pringles curve
last 2 are back R and L
Yeah, the second one is definitely not squished enough.
If this were mine I would probably lower the Z a bit and try to split the difference.
