Do I need the Original Prusa i3 MK2.5S/MK3S Multi Material 2S upgrade kit (MMU2S)?
prusanewuser
(@prusanewuser)
Hi, I need some clarifications. From the online store, the Original Prusa i3 MK3S kit seems to hold two spools. Am I correct that if I am willing to manually change the filaments to the printer during the print process, no extra kit is required. However, if I want to use solvable support or do not want to change the color manually all the time during the print process, I need to buy the following product. Am I correct?
https://shop.prusa3d.com/en/upgrades/183-original-prusa-i3-mk25smk3s-multi-material-2s-upgrade-kit-mmu2s.html#
Does the software allow the user to decide where to change the color and what color filament is used?
Postato : 03/07/2019 8:30 pm
RE: Do I need the Original Prusa i3 MK2.5S/MK3S Multi Material 2S upgrade kit (MMU2S)?
Hi Peter,
This link points to an old thread which was based on an earlier version of the slicer software, https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu/#post-100939
all of the relevant controls are in the current Prusa Slicer, just in different places.
I hope this helps...
If your model require a lot of changes, the MMU2s or Pallette 2 may be a better option.
P.S.you.can.change.colour by layer height as well.
Postato : 03/07/2019 10:13 pm
prusanewuser
(@prusanewuser)
Posted by: joan.t
Hi Peter,
Thanks. Yes, I saw a video about cutting the filament to stop the printer. Then changed the filament to a different color one and continued.
Am I correct that if I print with solvable support, I need the MMU2S ?
Postato : 03/07/2019 11:13 pm
almost certainly yes!
Joan
Postato : 03/07/2019 11:30 pm
badabaro
(@badabaro)
Hi!
Sorry if this is a quite basic question but I'm new at 3D printing.
Is this a whole-proper printer or an update in case you already have the old version?
Thanks! 🤓
Postato : 22/03/2020 11:10 am
