Dimensional acurracy calibration
janci
(@janci)
Hello,
After upgrading firmware to 3.13.1 and doing XYZ calibration and first layer calibration I printed this 100x100 calibration model https://www.printables.com/model/239603-100x100x100-calibration/files
And wanted to calibrate dimensional acurracy.
I measured the printout and got following results:
As you can see, the error is increasing with increasing length. So this is not simply error of outer perimeter thicnkess, as I assume that would be constant accross all measurements. There is a linear component to these errors.
I plotted this with linear regression line shown below:
Measurement result
As I understand it, the components of the error are:
  • 0,00316 in slope (scale)
  • -0,025 mm in intercept (offset)
I guess the slope error should be compensated by steps per mm setting.
But I am not sure how the built-in XYZ calibration of the printer affects this.
Does the XYZ calib modify/compensate scale, or skew only?
Should I modify steps per mm using M92 G-Code?
And how do I compensate for the outer perimeter thickness (the offset above) ?
Napsal : 14/02/2023 12:11 pm
RE: Dimensional acurracy calibration
If you look at it as percentage, it's actually stable, from 0.36% to 0.32% and well within the limits of hobby-grade FDM accuracy (0.3-0.5%). You could adjust your extrusion multiplier but, in the end much of the accuracy you can expect depends on model geometry and trial and error is usually required.
Napsal : 14/02/2023 4:27 pm
Also whats the shrinkage % of the material you are printing in.  Which is another factor to consider.  Did you measure Z too ?  From other data it seems that Z gets less shrinkage than X/Y.
Napsal : 14/02/2023 6:05 pm
janci
(@janci)
Good idea about the thermal expansion.
Will print some separate test points to eliminate termal expansion and share the results.
I did not print the Z test model, only XY.
Napsal : 14/02/2023 7:25 pm
