'Continuous' printing on the Prusa I3 series
jsw
 jsw
(@jsw)
This came in on one of those daily 3d print newsletters that I've subscribed to.  I'm definitely not recommending this, but it's novel and some may be interested in it.
It's kind of a Rube Goldberg-ish device that scrapes a finished print off of the build plate, supposedly allowing 'continuous' production.
The link below explains it and has a very brief video showing the device in action.
https://www.fabbaloo.com/news/new-open-source-mod-for-continuous-3d-printing-on-the-prusa-mk3s
I can see a number of issues, mainly involving the lack of a wipe-off of the build plate between prints, issues with prints requiring an adhesion booster, and recovery from a failed print due to about anything.
Opublikowany : 08/07/2022 8:42 am
RE: 'Continuous' printing on the Prusa I3 series
Posted by: @jsw
I agree.  The lack of a true cleaning mechanism could result in a need for a clean-up on aisle 4.
Opublikowany : 08/07/2022 11:01 am
Zbigniew Trzepizur
(@zbigniew-trzepizur)
Yeah... I was pondering making a diss post about this and decided against but since you've mentioned it... 🙂 I can't imagine how anyone could think this is a good idea. And it's not the only mod "product" of this type on the market. Abusing the extruder and the drive mechanics to blindly try to forcibly knock the prints off the print bed is just wrong on so many levels to the point of making me angry. Your printer's extruder is not a bloody bulldozer and the delicate parts like print fan mounts were never meant to wrestle prints off the print surface, for crying out loud. I've seen some video reviews of a different but conceptually identical product where the extruder tries to move the print off the bed by crashing into it, struggles to do so, ruins half of the print by breaking into it and then skips and makes loud cracking noises as the mechanics struggle and give up under the load. IMO it's a typical example of a "kickstarter culture" where a bunch of developer kids with no engineering background figure that if they know how to modify some GCODE programatically, it's automatically a good idea. If I were a Prusa employee I'd make a sticky post on the main webpage explicitly discouraging this type of garbage and voiding any and all printer warranties if the user is found to have used one as this seems nothing short of a support nightmare.
Just to be clear, my ranting is not directed to you, jsw in any way and I'm sorry if my post came across this way 😉
Zbigniew Trzepizur
My bad for not noticing the motorised  "knock-off bar" in this particular implementation. Still a terrible idea, though!
Opublikowany : 08/07/2022 11:14 am
jsw
 jsw
(@jsw)
Yeah, the more I think of this, the more I think of it as creating more problems than it solves.
LOL, 'If you think the MMU2S is a pain in the @$$!'  😉
I also see a belt running from the additional stepper motor over to the right side of the frame, and I can't figure out what it's for.
The RepRap style printers are really piecemeal devices, and to try to do 'continuous' prints seems like an exercise in futility.  I can see this device totally breaking down over the first large-footprint print that requires flexing of the build plate to release.
Opublikowany : 08/07/2022 11:20 am
Zbigniew Trzepizur
Posted by: @jsw
Exactly, for one of the myriad problems I can see with this, you don't exclusively use shearing force to remove prints manually, i.e. I haven't seen anyone grabbing their print and pulling it towards them as hard as they can. The creators may be putting countless disclaimers like "but... but... but... I's for small prints only!" but people being people, the first thing many potential buyers would do is to test just how far they could push it (pun intended). I fully agree it won't ever achieve  its intended purpose of being a solution for an unattended semi-volume production method.
Opublikowany : 08/07/2022 11:29 am
Thomas Lynch
(@thomas-lynch)
Hey, I am an engineer and I really think that is a bad idea. Just think of all the abuse the build plate will take from such a contraption.
But being an engineer I have a better one. You make the build plate a like a conveyor belt. After the print is done it automatically starts rolling forward and the print just pops right off and you are ready for the next print.  We can all dream, can't we?
Opublikowany : 08/07/2022 3:57 pm
Posted by: @thomas-lynch
I have a neighbor who bought one of the Creality printers with the conveyor belt models.  It does not work well.
Opublikowany : 08/07/2022 4:01 pm
Thomas Lynch
(@thomas-lynch)
Thanks for the tip. I'll cancel the R&D project
Opublikowany : 08/07/2022 4:19 pm
The kind of thing that *may* work for some but almost certainly *won't* work for all prints. Almost every day I see an example of something that needs a bit more than average persuasion to leave its comfy spot on the steel sheet ...
Opublikowany : 08/07/2022 5:11 pm
Lichtjaeger
(@lichtjaeger)
Opublikowany : 08/07/2022 5:58 pm
jsw
 jsw
(@jsw)
Another thing I thought of while thinking about the issue of any larger print that needs a flexing to cleanly release.
For almost any ABS print, and for any print of significant size in PETg or PLA, I'll always let the print and the plate cool down to almost room temperature before attempting removal.
Unless the build plate and print are removed from the heatbed, this means letting the whole assembly cool down, taking several minutes.  (I will almost always remove the build plate and set it aside to let it cool.)  With such an automated contraption, this would be very time consuming, requiring a cool-down and a re-heat for each cycle.  (Not even considering the thermal stress on the parts of the machine.)
Opublikowany : 08/07/2022 8:18 pm
oriddlero
(@oriddlero)
Very shortly im buying one of these mofos 😀 -
If my post helps you please consider downloading & making one of my most popular Prusa-Printables 3D models below:1. Ultimate Printer Knob Upgrade - The Best Knob of Both Worlds 2. Prusa MK3S Right…
Opublikowany : 12/07/2022 3:07 am
jsw
 jsw
(@jsw)
I've actually seen those in operation, both in the context of commercial units at trade shows and user-built ones at Maker Faires and such.
(I have no clue what I would ever use one of them for, however.)
Opublikowany : 12/07/2022 4:54 am
Wow, but for 10K, just buy more printers.
Posted by: @oriddlero
Opublikowany : 12/07/2022 9:54 am
