Change steel sheet, always First Layer Calibration?
montejw360
(@montejw360)
When I change steel sheets on the hotbed is "First Layer Calibration" always what I need to do? I have a smooth and a textured sheets, they are different thickness.
thanks,
Monte
MK3, firmware 3.14.0
Best Answer by Diem:
Every time you use a new sheet recalbration is necessary - but you can store the details against the name of the sheet for later reload - LCD menu.
Opublikowany : 05/08/2024 4:22 am
Opublikowany : 05/08/2024 4:41 pm
montejw360
(@montejw360)
RE: Change steel sheet, always First Layer Calibration?
Thanks. Didn't know value could be stored.
Opublikowany : 05/08/2024 5:15 pm
Robin
(@robin)
If there only where a place to look things like that up....
Wait! https://help.prusa3d.com/article/steel-sheet-profiles_1955
Opublikowany : 20/08/2024 10:56 am
