Can we ask the printer to make a beep sound once printing is done?
prusanewuser
(@prusanewuser)
Hi, I need to keep checking the print process as it is in another room. Is it possible to make the printer to produce a beep sound or a short melody once it has done printing?
Opublikowany : 15/05/2020 6:45 pm
Agkirk
(@agkirk)
RE: Can we ask the printer to make a beep sound once printing is done?
The answer is yes.  You will need to add statements to the g-code.  I have never done this so do not which statements are needed.
Opublikowany : 15/05/2020 7:11 pm
There's an old thread on this. I personally hate loud beeps, but insert little chirps at various times during the print by adding this line to start and end gcode under Printer Settings->Custom g-code:
M300 S40 P10 ; chirp
Opublikowany : 15/05/2020 7:25 pm
Posted by: @peter-c20
I'm using this simply sequence at the gcode end section:
M300 S1000 P500 ;First beep
M300 S0 P500 ;Wait
M300 S1000 P1000 ;Second beep
M300 S0 P500 ;Wait
M300 S1000 P1500 ;Third beep
Opublikowany : 15/05/2020 9:40 pm
4 ludzie polubili
Josef Möllers
(@josef-mollers)
Can this be configured to be included in all gcode files created by PrusaSlicer?
Thanks,
Josef
Opublikowany : 04/07/2022 1:50 pm
if you add the gcode to the Custom Gcode, End Gcode and save the profile, you  can re use it as often as you like.
Opublikowany : 04/07/2022 6:02 pm
set PS to expertmode:
..and add the gcode to the "End G-code" section.
wbr,
Karl
Opublikowany : 04/07/2022 6:29 pm
1 ludzie polubili
