CAD to rotate a two-dimensional image around a Y axis?
CJSHayward
(@cjshayward)
One of the things I have wanted to do is recreate a dish I made in a pottery class: roughly what would be obtained by rotating the attached image around the Y-axis. It's a bowl of sorts with a smaller raised bowl in the center.
What would be the recommended way to do this? Is it straightforwardly doable in TinkerCad? Should I be using another tool if I want (in this case) to create a solid by rotating something around its center?
This may not be the best beginner project, but I thought I'd ask.
Attachment removed
I invite you to visit my website at CJSHayward.com and my bookshelf at CJSHayward.com/books.
Respondido : 30/04/2021 3:19 pm
kpreid
(@kpreid)
RE: CAD to rotate a two-dimensional image around a Y axis?
If you can get the shape as a SVG or DXF file, then OpenSCAD can construct the 3D shape for you, potentially as simply as rotate_extrude() import("shape.svg");
Respondido : 30/04/2021 3:55 pm
Posted by: @cjshayward
Attachment removed
If you would provide a DXF file, I could create a STEP or STL file for you.
Respondido : 30/04/2021 4:46 pm
Ringarn67
(@ringarn67)
My take on The Bowl, made in fusion 360.
I have no idea about any other cadprogram
85mm in dia, resize it to suitable size
Attachment removed
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 30/04/2021 9:17 pm
Ringarn67
(@ringarn67)
And in LowPoly
Attachment removed
jsw
 jsw
(@jsw)
In FreeCAD you can 'revolve' a face around an axis to make a solid of that profile.
Respondido : 30/04/2021 10:32 pm
Swiss_Cheese
(@swiss_cheese)
Also known as lathe, or lofting, this can be done in several programs although the name of the function may change the process is fairly straight forward, to rotate a spline around an axis or another splines axis, it can also be termed as Nurms or Nurbs, depending on the software.
The Filament Whisperer
Respondido : 01/05/2021 1:07 am
jwvaughn
(@jwvaughn)
I think it can be done in FreeCad.  I was not very particular on the splines but you get the idea. Click on the image to see it all.
Esta publicación ha sido modificada el hace 5 years por jwvaughn
Respondido : 01/05/2021 5:51 am
jsw
 jsw
(@jsw)
Posted by: @jwvaughn
I've done a number of drafts in FreeCAD where I started with a good high-contrast photo, converted to .svg, and then promoted to a face and extruded to a solid.  I have not had the need to do a revolve to a solid, but it appears to be similar and I'm confident that I could do it.
Respondido : 01/05/2021 9:10 am
towlerg
(@towlerg)
Easy in Design Spark.
Respondido : 01/05/2021 11:02 am
