Buzzing fan at startup
Bill Lugg
(@bill-lugg)
I've noticed that the Noctua(?) fan, the one that sits at an angle in front of the print head, on my Original Prusa i3 MK3S has been making a nasty buzzing sound when I first turn it on for about two or three seconds.  When I start to print and it finally comes on, it sounds fine...until today when it started buzzing for a little bit and then quieted down.
Is this normal behavior or should I be seeking a replacement?
FWIW, prints seem to be coming out OK, but they won't if the fan fails.
Thanks
Bill Lugg
Bill Lugg
Respondido : 02/05/2020 10:07 pm
RE: Buzzing fan at startup
Hi Bill,
the liklihood is that the bearings are wearing out.
you could try peeling the label off the hub, and putting a couple of drops of oil into the bearing, then wipe the surface clean, and put the sticker back again.
regards Joan.
Probably also worth ordering a replacement for when you need it!
Respondido : 03/05/2020 1:07 am
me gusta
Bill Lugg
(@bill-lugg)
The printer is only about 5 months old and hasn't run a full kg of filament through it yet.  So, I think it might be a case of infant mortality then.
Thanks for the input.
Bill Lugg
Bill Lugg
Respondido : 03/05/2020 3:48 am
Have a word with Prusa Chat,
the fans should last quite a while. it if is infant mortality then they will replace the part!
Respondido : 03/05/2020 9:33 am
