[Solved] boot loop on first startup
worldwidejoe
(@worldwidejoe)
Hello all, I just finished my first build and when I turned on the printer for the first time, it asks me if I want to go through the setup. I click yes and the screen briefly says "sorting files" and then it goes back to the screen where it asks me if I want to do the setup again. Some sort of boot loop..  Please let me know if anyone has any ideas, thank you very much.
Napsal : 27/10/2019 7:23 am
RH_Dreambox
(@rh_dreambox)
RE: boot loop on first startup
You probably press the reset button (X) instead of the round button 🙂
Napsal : 27/10/2019 8:32 am
worldwidejoe
(@worldwidejoe)
@rhdreambox
I did. I'm sorry. Thank you.  🙂
Napsal : 27/10/2019 5:23 pm
rmm200
(@rmm200)
Go easy on yourself. You are not the first. There should be a page when you get your kit or machine:
"Warning - the big X is not an enter button. It is a Reset".
Napsal : 27/10/2019 11:15 pm
Drake Christensen
(@drake-christensen)
Happened to me.  Not at all obvious.  If Josef ever updates the LCD board he should move the reset away from the spinner, to make it more obvious that they don't really go together
Napsal : 31/01/2021 1:00 am
