Best support for multi filament ?
Hades
(@hades)
Hello,
Trying to find the answer since 1 hour, without success so calling for help.
What is the best support for filaments you are using for MM2S multi filament prints ?
I have seen different solutions, but I would like to get the feedback of experienced users.
Thanks in advance !
Postato : 25/01/2023 5:20 pm
RE: Best support for multi filament ?
I have used PLA as support for PETG. never had much luck with PVA
you need plenty of  Purging volume between the filament changes!
Postato : 25/01/2023 5:27 pm
Hades
(@hades)
By support I was meaning the piece on which the filament stands and turn. I don't know if there is another special word for it. I would like to have 5 filaments loaded upper the printer. Where can I find an STL & explanations on how to build this ?
Postato : 25/01/2023 5:30 pm
on the MMU2S, I have my filaments on a shelf over the printer
I use this sort of spool holder on the shelf,
Joan
Postato : 25/01/2023 8:43 pm
1 persone hanno apprezzato
Hades
(@hades)
Looks nice, will think about a solution close to this.
Postato : 26/01/2023 12:07 am
Robin
(@robin)
I am using the LACK enclosure V2 with the original MMU2 buffer installed on top and mounted spool holders for PLA and dry boxes connected to the buffer for PETG, PVA+ and ASA. I am quite happy with this setup...
Postato : 29/01/2023 1:07 pm
Hades
(@hades)
Looking nice too, but don't have the space to put an enclosure here unfortunately.
Postato : 29/01/2023 4:43 pm
