Bed leveling causing messy starts
CastIronFace
(@castironface)
This is probably a super noob question, but every time I start a print it starts by doing a bed level routine and leaving little blobs at each of the 9 spots. I hover like a helicopter parent and frantically clean them off before the actual print starts, but it's hard cause the printer is so dang fast 🙂 Is there a way to change this behavior or am I doing something wrong?
Respondido : 15/04/2018 5:06 pm
Koen Kooi
(@koen-kooi)
Re: Bed leveling causing messy starts
I replaced the start gcode in slic3r with this:
M115 U3.1.1-RC4 ; tell printer latest fw version
M83 ; extruder relative mode
M104 S120 ; set extruder temp low for mesh level to avoid blobs and strings
M140 S[first_layer_bed_temperature] ; set bed temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
M104 S[first_layer_temperature] ; set extruder temp
G80 ; mesh bed leveling
G81
M109 S[first_layer_temperature] ; wait for extruder temp
G1 Y-3.0 F1000.0 ; go outside print area
G92 E0.0
G92 E0.0
M221 S95
Respondido : 15/04/2018 8:43 pm
CastIronFace
(@castironface)
Thanks a ton! A few prints in and it's working as expected.
Respondido : 20/04/2018 3:33 am
Kyle
 Kyle
(@kyle-3)
What did that change, nothing is jumping out at me
Respondido : 22/04/2018 2:45 am
Kwaad2
(@kwaad2)
keeps nozzle cool until bed is up to temp, it will reduce oozing BEFORE the bed leveling, however it does nothing during.
M115 U3.1.1-RC5 ; tell printer latest fw version
M201 X1000 Y1000 Z200 E5000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm/sec
M204 S1250 T1250 ; sets acceleration (S) and retract acceleration (T)
M205 X10 Y10 Z0.4 E2.5 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M104 S{first_layer_temperature[0] - 40} ; Set nozzle temp 40c below first layer temp.
{if first_layer_temperature[0] < 241}M106 S255{endif} ; wait extruder temp
M106 S0 ; Turn cooling fan off before printing anything
G92 E0.0
G92 E0.0
M221 S{if layer_height<0.075}100{else}95{endif}
Here's mine.
It does a lot. 🙂
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Respondido : 22/04/2018 5:40 am
david.h61
(@david-h61)
I am going to try this. Mine leaves a glob at point 4 of the bed leveling.
Respondido : 22/04/2018 4:56 pm
