Bed Adhesion
chris.w19
(@chris-w19)
Bed Adhesion
My prints recently stopped adhering to the bed, the fulfillment on the first layer tears, lifts up or folds back on itself. I have cleaned the bed with acetone and IPA, I have re calibrated the xyz, re calibrated the z height and nothing. Any ideas?
Publié : 02/05/2018 5:11 pm
chris.w19
(@chris-w19)
Re: Bed Adhesion
I'm also using the PE Slic3r with default settings for the mk3
Publié : 02/05/2018 5:16 pm
ACDawg
(@acdawg)
Re: Bed Adhesion
Some pictures of failed first layers would be good. It may not have to do with the PEI, but more with your Z offset.
Publié : 02/05/2018 5:21 pm
CorpseGuard
(@corpseguard)
Re: Bed Adhesion
Who says to you that you should use Aceton??? Aceton kills your PEI sheet
reid.b
(@reid-b)
Re: Bed Adhesion
Try washing it with dish soap and hot water, just like you wash your dishes. Dry it off with a clean towel, and don't put anything else on the bed. This procedure works like magic for me and many others...
Publié : 02/05/2018 5:35 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Bed Adhesion
No not true. Acetone on occasion refreshed the stick of the PEI.
Peter
Publié : 02/05/2018 5:42 pm
ACDawg
(@acdawg)
Re: Bed Adhesion
https://www.prusa3d.com/downloads/manual/prusa3d_manual_mk3_en.pdf 12.1.5
Publié : 02/05/2018 5:44 pm
imod.systems
(@imod-systems)
Re: Bed Adhesion
Overuse of acetone will make your PEI sheet brittle and will cause damage over time. Acetone should be a last ditch effort if 90%+ Iso alcohol, windex, or dish soap do not work.
Publié : 02/05/2018 9:13 pm
dimprov
(@dimprov)
Re: Bed Adhesion
In his guide for new users, Prusa himself says to use acetone about once a week to revitalize the print surface:
Dish soap residue sounds like it would be a bond breaker, so I have doubts that it would be wise to use it.
Publié : 02/05/2018 11:44 pm
reid.b
(@reid-b)
Re: Bed Adhesion
That coming from someone who obviously has not tried it, vs. the many of us who have. YES, it works, NO, it leaves no residue. That's because you RINSE when done.
Publié : 03/05/2018 12:27 am
dimprov
(@dimprov)
Re: Bed Adhesion
Well, I don't see dish soap as one of Tom Sanlanderer's recommendations: https://toms3d.org/2017/05/08/guide-restoring-maintaining-pei-printbed/
I guess that must be because he hasn't tried it either. 😉
Publié : 03/05/2018 2:01 am
Joe Prints
(@joe-prints)
Re: Bed Adhesion
When 90% IPA doesn't work anymore, I lightly scrub the bed unheated with the firm side of a new kitchen sponge. I just scuffs it enough without "sanding" through the PEI. Clean it off with 90% and it's just like new
Anything can be made better
https://www.myminifactory.com/users/Joe%20Prints
Publié : 03/05/2018 2:17 am
rob.l6
(@rob-l6)
Re: Bed Adhesion
Occasional application of Acetone is what I use. It certainly brings back the bed adhesion close to new.
When PLA is no longer sticking, it's time for an Acetone bath 😉
Publié : 03/05/2018 4:01 am
GertL
(@gertl)
Re: Bed Adhesion
After my upgrade to MK2.5 i couldnt get anything to stick properly.
(yes, LIve-Z was good).
I washed the PEI with soap and water, cleaned it with Acetone and then 99% IPA. Now everything sticks as good as the old MK2S PEI.
Got the feeling that the PEI maybe wasnt totally clean when delivered.
Gert
Publié : 03/05/2018 8:36 am
